How to do a smooth section between two levels
Bit new here; Sorry in advance,
I am designing a table and I'm designing a foot cap, so it dont damage the floor,
I have 2 cylinders, one 10mm diameter, 10mm high and a 5mm diameter, 5mm high one on top as a part, my question how do i transition between these two levels in the part
leowarren34
I believe I know what you want; there are 2 options, one is loft be selecting the 2 surface and rails which gives a smooth transition.
The other option is revolve which only works if you have a circular surface, you can make a frame and revolve around an axis
Hope this helps
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
leowarren34
With your dimensions
I made this:
Hope this is useful
Leo Warren
That's what I was looking for,
