How to Display a Grid Floor in a Assembly file
billjenkins
billjenkins
Will someone please tell me how to display a grid floor in a Inventor Assembly file? I can't find the option and I have accomplished this in the past.
I use Inventor Pro 2009 and Windows 7 32 bit.
JDMather
Do you mean View>Ground Plane>Settings?
mcgyvr
define a grid floor?
JD assumed you meant a grid on the ground plane.. (or is just pulling your leg due to lack of specifics in your question)
I assumed floor grating typically seen in industrial plants?
This would typically be accomplished by a texture image applied to that face/body
See why details/specifics are important.. Smiley Wink
billjenkins
Thanks for the immediate responses! Here is a video and at the end you will see the type of grid I called a floor.
https://www.youtube.com/watch?v=t2KJnT5jQng
I seem to remember doing this with a simple setting change in Application Oprions in InvPro 2009 but I can't find it.
Thanks!
mflayler
Thats an old Application Color background.  Not sure if it is still in the newer versions of Inventor but you would change it here...its not really a "floor" though.
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
JDMather
Tools.Application Options>Colors Background
Edit:
- what Mark said.
billjenkins
Solved -Thanks a bunch!
