When exporting flat patterns to .dxf files I currently have to either edit each .dxf file to remove the line centre and tangent fold lines, or create a sketch on the flat pattern and use project geometry and export the sketch.
I have been told you can disable exporting of fold lines and just directly export flat patterns without fold lines: "You need to set the visibility of layers in the export settings. If you save the export template, the variant will be repeated automatically."
However I can't seem to find these options.
Any help appreciated, thanks.
