How To Dimension Bolt Circle?
xapex93586
Message 1 of 8
xapex93586
Can't get Center Pattern to work without a reference center. Thank you.
Replies (7)
Message 2 of 8
jtylerbc
Was it modeled as a pattern?
If so, Automated Centerlines can create the bolt circle even though there is no center to manually click on.
Message 3 of 8
xapex93586
Sheetmetal cut of a circular sketch pattern. Auto centerline doesn't work.
Message 4 of 8
kacper.suchomski
Hi
Standar centerline done it.
Kacper Suchomski
Message 5 of 8
jtylerbc
@kacper.suchomski, for some reason I always forget you can do that.
Message 6 of 8
xapex93586
Thanks for the video but my holes are made with extrude cuts, not the hole command. When I use the "Centered Pattern" command I get your 0:49-0:52.
Can you tell me what command you're using at 0:53?  I don't have that circular menu.
Message 7 of 8
kacper.suchomski
As I wrote in the post - standard center line.
This radial menu is just a keyboard shortcut.
Kacper Suchomski
Message 8 of 8
xapex93586
Thank you
