06:02 AM
Hi
I want to delete sections of my part which interfer with each other but I get an error message.
I do the following steps:
1. first compile the assembly from the two parts ('header pipe' and 'AIV branch') and constrain
2. run an 'Analyse Interference' check and found that there is a small interference (see below):
3. In assembly I double click on the 'header pipe' part
4. I 'copy part' for the 'AIV branch'
5. I use 'scuplt' commands, but it produced the following error:
Can you advise what I am doing wrong?
I simply want to delete any overlapping material.
Danny
