Hi all,
Sadly a fairly basic user of Inventor 2021/Win10 here. I'm trying to make a model that involves cutting a hole in a curved surface. I can define the cut I want using 4 custom planes, but each end of the cut "box" is actually a curve, because the those 2 planes are 3 deg off from vertical. I can't figure out how to define the curve of each end so as to project a cut from a 2D plane tangent to the curve, so I tried to define the cut by planes - but now I can't figure out how to use those planes to define the cut. I hope the attached pics and model show what I mean.
FYI, the part in question is a glassfibre panel, but I've modelled it as sheet metal because after making the cut, I want to flatten the panel, export a DXF from the face, laser-cut it in thin card and use the card as a template to mark out the actual cut on the panel.
Please could some kind soul advise as to how best to do this?
Is it better to model this as a surface, cut it, convert it to a solid, then to sheet metal for flattening?
Thanks for any help you can offer
You can use Split and select the body option to break the body into multiple parts at each plane. For the first 3 splits you should use use the option to Keep both sides. The last split you can use to remove the hole. You can then combine the bodies back into a single body.
Hi Peter,
On top of what Scott and Sam already suggested, you may want to try Cut Normal. I believe you are trying to create a cut so that a square rod can go through, right? Then Cut Normal is the option to use. Just create the square profile. Use Cut command -> check Cut Normal -> Through All.
Many thanks!
