How to cut a part of circle
Message 1 of 32
How can i cut some of the circle in Inventor so i can go from the first picture to the second ?
I made the "pipe" with sweep.
Is it easy to draw a pipe with sweep..?
I guess i need an innercircle and an outer circle to it...
Here i just have a "massive" pipe without hole..
Or can i use som  command in  Inventor for this purpose, so i can draw a pipe much easier ?
Replies (31)
Message 2 of 32
luisalfredovazquez1995
Hi!
You can model a pipe drawing two concentric circles and then you extrude only the area between the circles.
The pipe´s length will be the length of the extrusion operation.
Sweep operation is commonly use for irregular paths. Also you migth use it for straight pieces, but it is not common.
Message 3 of 32
JDMather
Attach your *.ipt file here.
Tip: You can use the built in Windows Snipping Tool to grab clear screen shots.
Message 4 of 32
Thank you for your answer.
But I need to draw a path (center for the two circles) first and then i can extrude the pipe along the path. Is it right way to do it?
And how can i draw a pipe like in my picture? The path should not be a complet circle. I guess i have to draw a circle for the path, and then I have to
measure from top point of the circle, the heigth of my construction, so i get a part of a circle. But how do I "delete" the part of the path that i dont need?
It would be easier if i could choose a pipe and material, and draw a centerline for the pipe. When drawing the part of a circle, could delete lines and path like in the Windows program "paint".
I need to choose material for the pipe and afterwards calculate strength, G powers and so on.
Also i need to cut the pipe in 5 pieces so  i  can assemble the pipe parts afterwards.
Så i hope its possible to do some editing afterwards, after the extruding.....
Message 5 of 32
JDMather
All of this is possible.
Message 6 of 32
Here is a way. I do not know if this it is what you want to do.
Message 7 of 32
I think i can use trim. But my pipe is a little bit different. Its like a portal, and its not a half pipe. Path is the concentric circles. It has to be like the drawings i attached. But only a part of the circle. Its difficult to explain but i dont know how to explain it better...
Message 8 of 32
But how is my big question ..
Message 9 of 32
These 2 photos illustrate what i need. Hope it is clear that the pipe itself, is a part of a circle.
Message 10 of 32
In this example I used splines lines to draw the path, but if you need a part of a circle, then you can use a circle and then cut the part you need.
Watch the next video:
https://knowledge.autodesk.com/community/screencast/f22ae47f-af48-4e28-9d6d-5d78d1202665
Let me know If the video was useful.
Message 11 of 32
Looks good, but a little bit fast presentation 🙂 But fine  with your help !
I have a circle now but i have difficulties with the "Normal to a curve at a point".. i cant see the normal plane when i zoom in ?
I also guess that i need two concentric circles to get the pipe. And i only need some of the circle..
But one step is better than no steps 🙂
Message 12 of 32
JDMather
You did not specify the OD an ID of the Pipe wall?
Is something like the Attached what you are after?
Message 13 of 32
Yes exactly !
Nice
But it has to be like in attached file 🙂
Message 14 of 32
JDMather
See Attached.
Message 15 of 32
Yes ! Thank you very much !!
How can i see the measurement ?
Message 16 of 32
JDMather
I attached a simplified version 4 above.
Message 17 of 32
oh fine 🙂
I just have to be familiar with inventor to see where and how to see the measurements. But i learn every day 🙂
Is it possible to see the length of the pipe somewhere , and how ?
Message 18 of 32
JDMather
I recommend that you sign up for a class - this is all very basic stuff.
Do you know how to Edit Sketch?
Message 19 of 32
yes i will 🙂
Last thing today 🙂 how do i see total length of the pipe ?
I have tried to but can see all the other measurements, but not this...
Message 20 of 32
JDMather
Do you want the length before it is bent, or the length after it is bent (it will stretch in the bending process).
