Tell me where the display of the base point is adjusted. It must be done twice as small.
Solved by SBix26. Go to Solution.
With just a bit of experimentation, I found that the size is controlled by the Leader style terminator size, shown below. You'll probably want to create a separate style for your Origin Indicator (the terminology Inventor uses) so that you don't mess up other annotations that use that same style.
Update: note that the Size parameter is the controlling parameter, but the actual size of the Origin Indicator circle is 3.2 times that number-- in the example below, the OI diameter is exactly 8mm.
Sam B
Inventor Pro 2021.1 | Windows 10 Home 1903
LinkedIn
