Hello again. So I've got this part that needs to adjusted like below. I have lofts, boundary patches and various surfaces. I'm not sure how you can manipulate an existing surface or make a new one that can look like the shape below. Check out the cross section:
Here is where it is now:
I'm trying to make the shape more like how the red line shows on the left. In doing so the flat spot will also be gotten rid of. How can I achieve this?
Any help is greatly appreciated!
Solved by WHolzwarth. Go to Solution.
- Expand the Sculpt
- Set LoftSurface14 visible
- Edit it according to the screenshot. You can play with the weight (actually set to 0,5)
Walter
Walter Holzwarth
Once again WH! You never disappoint! Thanks so much! Hopefully these posts help other people as well.
