How to create and customize ipt and idw templates
How to create and customize ipt and idw templates and make it the default in inventor when starting a new file?
JDMather
Make your desired changes and then Save As>Save as Template and overwrite your Standard templates.
(Or you could change path to point to custom templates.)
Thanks for the help, If I use ilogic and save the template file will ilogic go with the file or will I have to configure it again?
johnsonshiue
Hi! Yes, an iLogic rule embedded in the template carries over to the new document. You don't need to recreate the rule.
Many thanks!
Software Test Engineer
