how to create a twisted cylinder shape with a thick middle section
ead4385
Message 1 of 10
ead4385
Hi basically I want to combine these 2 shapes, I have tried sweeping a cut to the first shape with bad results. Is there a simple way to do this?1.png2.png
Replies (9)
Message 2 of 10
theo.bot
You could try it with a loft. use 4 sketches to create the single surface shape. Then use pattern and sculpt to make the solid. I included my sample.
Message 3 of 10
ead4385
thank you very much!! I also tried loft but was unsuccessful.
Message 4 of 10
ead4385
I have checked your solution and I really like it, I would never have thought of using 2 planes to connect the arcs. I have learned something new thank you!! 😄
Message 5 of 10
johnsonshiue
Hi Folks,
This can also be done using Guide Rail Sweep. Please take a look at the attached part. I think the surface will be smoother using this approach.
Many thanks!
Software Test Engineer
Message 6 of 10
ead4385
Beautiful!:D You also managed to do it in fewer steps!
I hope you dont mind if I ask a follow up question 😆
So I shelled the solid, did a split and tried to put lips and grooves on the two bodies
My guess is the shape of the form is angled so it doesnt allow the cut,
how would you go about this problem?
Message 7 of 10
cadman777
I never use the Shell command b/c it's got a lot of caveats when trying to use other features with it.
I'm on IV2010, so maybe the Shell command has been improved since then.
Maybe others can say?
If not, then I would do it another way.
Maybe you can delete the top flat face to turn it into a surface.
Then you can use Thicken to make it a solid.
That may enable you to add other features.
Otherwise, you will be building on a feature (Shell) that will cause serious bottlenecks downstream.
And you'll probably have to do everything the hard way (using basic features) from here on out.
... Chris
Win 7 Pro 64 bit + IV 2010 Suite
ASUS X79 Deluxe
Intel i7 3820 4.4 O/C
64 Gig ADATA RAM
Nvidia Quadro M5000 8 Gig
3d Connexion Space Navigator
Message 8 of 10
ead4385
Hi, thanks for your reply! 🙂
That might work,
unfortunately I have worked on this shape for 2 days now
trying to make it a moldable plastic part :')
But no matter how I cut it, the draft angle (1°/24,5)is not compatible with this shape.
Unless I chop it up completely which leads to problems with lips and grooves.
Message 9 of 10
cadman777
Bummer!
Do you have a sketch of what you want to accomplish?
If you post it in here, maybe someone can figure something out?
... Chris
ASUS X79 Deluxe
64 Gig ADATA RAM
Message 10 of 10
johnsonshiue
Hi! Please share your attempt here. I can take a closer look. If the groove still fails, you may simply create a rectangular profile and cut it using Guide Surface Sweep (pick the adjacent face as a guide). The same profile can be reused as a lip.
Many thanks!
