Thanks for quick replies everyone. I'm new to the forum, how do I reply to multiple posts in one post? (a nice problem to have)
To clarify:
I have a jagged mullion and I want to pattern spigots up the side of it. However, I want to pattern them along a jagged line. To do this I thought I could create a sketch composed of points which indicate where I want the spigots to be, then use a "sketch driven pattern" command to propagate the spigots.
@Anonymous
"What exactly are you trying to achieve?
My first guess would be to reference the pattern dimensions to the corresponding dimension in the sketch"
See above.
@Anonymous
"Easy to do.
Attach your assembly here."
Can you recommend an easy way to send assemblies with all the parent/child links intact? I read the following guide:
http://cadsetterout.com/inventor-tutorials/copy-an-autodesk-inventor-design/#copy-design-sdk
I tried pack'n'go but it carried all my template files, which seemed unnecessary.
I tried the 'copy' command from the assemble tab and copied the assembly and the parts to a new folder but it only had a 16kB lock file in the folder.
Then I gave up and took screen shots.
@Anonymous
"You'll need to create work points in the part file itself using the rectangular pattern tool. You can create a path or curve to place your work points as needed. Then when you're in the assembly, switch over to model view and reference the part's rectangular pattern to pattern your component."
Hi Jacob, unfortunately the work points which I want to follow are not in a rectangular pattern, they're all jagged and at different distances apart too. It will be much faster for me to locate the parts using a sketch rather than constraining every part in three dimensions.
I see from your screen shot that you've created a curved pattern of balls using a rectangular pattern. Did you create a rectangular pattern then 'redirect' it along a sketch? I tried to follow you but I'm missing something.
Here are some screen shots of my attempt in a simplified model (far less parts to pattern). I have the part in the assembly (the cube/spigot) which I want to pattern and I have a sketch to indicate the multiple points where I want to pattern the part on to. However, I can't select the spigot as a feature to pattern using the "sketch driven" pattern command.
I can create a sketch driven pattern of a feature in a part but I don't want to do that. I want to create a sketch driven pattern of a part in an assembly.
Any ideas?
