how to create a animation
Message 1 of 12
im using inventor 2014. i was wondering if someone could help me in making an animation of this assembly?  what i was wanting to do is show the screw turning down tight then moving the horseshoe clamp to about the middle of the block then stop.
Replies (11)
Message 2 of 12
mcgyvr
first step is learning that an iam file is useless without all the ipt and any other subassembly iam files inside it.. Smiley Wink
An iam file does not include the parts in it self but only links to them..
Message 3 of 12
Ok I am new to all this I'm trying to learn all of this. This is all new to just started doing this earlier this year. So help on whatever I need to do is greatly appreciated.
Message 4 of 12
JDMather
Attach your *.ipt files here.
Message 5 of 12
Message 6 of 12
Message 7 of 12
Was wondering if anyone was able to give any pointers on how to do this. I submitted all the ipt for the animation that I wanted to make. Just need some guidance on how to do it. Thanks
Message 8 of 12
mcgyvr
I don't have the same version as you so I can't share whatever I have as you wouldn't be able to open it but
Read this..
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2015...
You just need to setup constraints that you drive.. and to get "fancy" with the screw do this..
and here https://www.youtube.com/watch?v=CapXPJXEegk
make sense?
Message 9 of 12
JDMather
Are you a student?
I noticed that many (most?) of your sketches are not fully defined, not even dimensioned.
What version of Inventor is your school using?
It would be easier to help if you installed later release of the software as 2014 is rather ancient.
http://www.autodesk.com/edcommunity  students, teachers and schools can all get the latest release at this site.
To make your life easier - the first thing I recommend is that you make use of obvious symmetry.
For example, in your handle.ipt change Extrusion1 to Symmetrical (midplane).
You could then Mate-Flush the XZ plane of the Bolt to the XY plane of the Handle to keep the handle centered in the bolt.
You will want to learn about Rotational/Translational constraint (screw motion) and Angle Constraints (Animate Constraint to impart motion).
Message 10 of 12
mcgyvr
@Anonymous wrote:
Are you a student?
And if you are a student do NOT install a new version if its different from what you are using at school as the files aren't backward compatible and you would no longer be able to open them up at school of you used a newer version at home..
Message 11 of 12
Yes I am a student. And the school uses 2014 version. I realize my drawings are rather crude as I am learning. I really appreciate all the help that I receive from the forum it has helped me a lot. How is it that I change and mate the handle and the bolt that you were talking about. I really want to learn the best and most effective ways to do these things. I am seriously looking at the possibility of doing this for a career. Thanks again for all the help
Message 12 of 12
WHolzwarth
Well, in Inventor's early days a steering part mostly was used for tasks like this. But a rotating workplane is possible, too, instead of a separate file.
Switching from rotation to linear movement is done with Min-Max parameters; look at parameters window.
2014 files attached in Zip, animation starts with Driveme angle constraint
Walter
Walter Holzwarth
