Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Inventor Forum
how to close the quotation marks
9 REPLIES 9
Message 1 of 10
francischen
600 Views, 9 Replies
Hi every experts.
I got a question in Inventor 2021, and this is my problem.
It shows these green quotation marks and red  dotted line.
Is any problem to close them?
thanks
9 REPLIES 9
Message 2 of 10
SharkDesign
in reply to: francischen
You mean the green corners?
That means it's a raster view.
Right click the view and choose 'make precise'
You can also double click the view and check if raster view is turned on in there.
  Expert Elite
  Inventor Certified Professional
Message 3 of 10
francischen
in reply to: SharkDesign
Hi @SharkDesign
Yes, i mean those green corners and dotted line.
It can't click the "make view precise".
and the dotted line always shows on the screen.
Message 4 of 10
SharkDesign
The dotted line should only be there if the view is selected.
If you right click the file in the browser, is defer updates turned on?
  Expert Elite
Message 5 of 10
A.Acheson
Likely the part or assembly was modified with the drawing opened and the synchronization has not gone through completely.
Manage rebuild all and save assembly and all necessary parts and close. If the raster view still continues save and close the drawing , in some case I even ended the inventor session then restarted.
Regards
Alan
Tags (2)
Message 6 of 10
francischen
I also confuse about this issue, but i didn't select the view.
Just check, and "defer updates" is turn off.
Could it be that the update was incomplete at the time?
Message 7 of 10
francischen
in reply to: A.Acheson
I might have done this at the beginning
and  is there a way to close it in the future?
Message 8 of 10
What do you mean with that?
Arthur Knoors
Autodesk Affiliations:
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
Message 9 of 10
@francischen
Your drawing is stuck in raster state.On large assemblies /complex parts it will  enter this mode while calculating the views. However it can become stuck. There are various ways to get it out of this including suppressing the view Unsuppressing or doing as @SharkDesign  and myself has suggested. your drawing shouldn’t be harmed by it and you can save but it will frustrate you if you want to finish it quickly.
The link below has many methods so you might have to view those posts.
https://forums.autodesk.com/t5/inventor-forum/drawing-views-stuck-in-raster-view/m-p/5125172/highlig...
Regards
Alan
Message 10 of 10
johnsonshiue
Hi! There are two logical explanation to the green brackets.
1. The view is a raster view (image based, as opposed to vector based). Right-click on the view -> Make View Precise.
2. The drawing view fails to finish updating as a precise view. Usually, you can go to Tools -> App Options -> Drawing -> uncheck "Enable background update."
If neither works, please share an example that exhibits the behavior.
Many thanks!
Software Test Engineer
