How to change text in dimension
Vagulus
Vagulus
I have a drawing which is largely standard for two parts.  Only a couple of dimensions need to change.
My idea is to use one drawing and present the changing dimensions in a table.  This would mean changing the 45 and 55 seen here with, say, A and B.
Can I do this in AI2018 and if so how?
"If you can't explain it to a six-year-old,
you don't understand it yourself"
Albert Einstein
see attached image. If I get your question correctly then this will help you.
Vagulus
Perfect.  Thanks
Albert Einstein
