How to Change Standard View Label Formatting?
raffael.leobino5D7GD
Observer Observer
Observer
Observer
Every time a create a new view, section or detail, I would like to display a standard label, the first row needed to have an underline, with 0.12 height, and second row should have 0.10 height without the underline. Also, the Scale text should have " : " after it.
<VIEW IDENTIFIER>
SCALE: <SCALE>
I've played around with styles editor and the only thing I managed to do was changing all the text to be underlined with 0.12 height. There's any way to change those default inventor view labels?
Frederick_Law
Click the text to edit.
Select the text and change height.
You can add : to scale.
Observer
Observer
The thing is: editing this in one label doesn't fix the others, I would have to repeat these steps for all the drawings.
Frederick_Law
You need to save it to Style library.
You could copy and make your Standard.
james_bennett3HDT7
Community Visitor
Community Visitor
Late to the party on this, but for anyone that ends up here looking for the answer:
Go to "Manage" --> "Styles Editor" then scroll to the top on the left hand side to find "Standard" group.
Expand this and select the active standard (the one with the blue box next to it).
Back on the right hand side, you can select the "View Preferences" tab.
Under this tab you will be able to change between multiple view types and update the default "Display" settings for each.
