How to Change or set Frame Generator skeleton frame not grounded to origin?
CamPhoenix
CamPhoenix
I have a situation when I create a frame using frame generator and the skeleton frame is not aligned to the origin point.
This alters my origin point when I convert my file to other cad formats. How can I reconfigure the skeleton frame to anchor a coincident point to the origin center point of the coordinate system.
As you can see in the image my origin point is away from the skeleton and I would like to somehow anchor a corner of the skeleton frame to the origin point. I am able to do so at the component level but not at the skeleton frame level.
kacper.suchomski
Hi
Simply create the appropriate constraints to position the component. You can use productivity tools for this.
Finally, use the Rebuild All command.
Kacper Suchomski
