How to change ilogic part instance - easy one I hope
I made a part that has several different variations.  I put one in an assembly.  It shows up as instance -01.  What is the easiest way to change it to -02?  I did it once, but can remember how I did it.  Now I can only figure to replace the part, select itself, then when it comes in pick the type.  Seems a long winded way to change the instance type.  Any faster way?  Thanks
found it.  In tree, right click on table and "change component"
