How to change AutoCAD title block color?
badkuki
badkuki
I have a predefined AutoCAD drawing which I need to convert to a title block which I need to use in my drawing. The problem is that the lines and text are in yellow and red colors which also shows up in the final exported PDF. I've searched everything, but no luck.
I went into AutoCAD and changed the line colors and then re-saved the title block, but it's still in those same red and yellow colors. I've also tried going into the Block properties and changed the color of the block to black, but it's still colored!
Any help would be appreciated! Tell me if I should provide more info!
Using Inventor 2020 Professional.
Here's a screenshot, I've censored some private info.
NigelHay
It might be easier, when you print to PDF, to just set all the line colours to black.
maBogues
So the answer  is layered because I can't see the file.
Start with editing the Tblock "Sketch Symbol"  Select RMB\Edit Definition.
Double Click the text (edit text) and change the color. done.
or
Double click the text and change to "by layer"
Select the text with Annotate tab showing a see what layer the text is on, say TT for example
Open Styles Editor, navigate to "Layer"
select the layer TT, and change the layer color to White or what ever.
Hope you get this done soon.
~Mike
