How to begin create this model?
Message 1 of 22
Hi
I will try to make this model but I don't know how to get further.
I attached what I tried. Have i started correct?
I have some problems.. if it is right what I have create so far I will tell my problems 🙂
Thanks in advance!
Replies (21)
Message 2 of 22
WHolzwarth
First issue: You've used a Control vertex spline for the curve. Delete it, and use an Interpolation spline instead. Expand the spline menu for that.
Another way can be editing Sketch10, right-click on the spline and Convert to Interpolation, but time will be the same as above, because of new point placement is needed.
IMO, Interpolation spline should be the default option in Spline menu
Walter Holzwarth
Message 3 of 22
I can't get my splines on the workppoints. If I zoom in I can see there is Space between spline and the circles and the ellipse. What to do then? 😕
Message 4 of 22
WHolzwarth
Well, I tried the Convert to Interpolation Spline option. It can be done, but it's worse than creating a new Interpolation spline with only 3 points. I had to delete most of the converted points.
For point matching, you need to project 3 points from bottom circle, intermediate eliipse, and top curve into Sketch10. After that you can place coincident constraints with the spline, and adapt the spline shape by Activate handles and placing an orthogonal constraint at the bottom.
Now to 2nd issue: Your top circle is incorrect. You need to create a 3D intersection curve with this circle and the side view radius instead.
New intermediate file attached.
Walter Holzwarth
Message 5 of 22
Hi
Thanks for your help!
I have created the to rails with interpolation spline, and there is no Space between the splines and cirkles/ellipse.
What should I do now?
The 15 deg in the top is also wrong.. how can I create it right?
I'm sorry but when there is much text I don't understand so much of what I need to do. If you can explain in point form instead maybe it will be better for me 😕
Thanks in advance!
Message 6 of 22
WHolzwarth
Both rails were not ok, because of the top end section.
This top end must be created as an 3D intersection curve of ircle 600 dia (=R300) and circle with 200 dia.2 Points (left and right) must be included
After that new 2DSketch11 and two guiding lines (15°), starting at these points.
Then another 2DSketch10 with projections from some lines of 2DSketch11, where a new outline spline can be set (Tangent to 15° guiding line, rectangular versus bottom line.
Smiley Wink Now do similar for a right outline spline.
Walter Holzwarth
Message 7 of 22
So I can't make the right spline in the skethces 10 and 11, where left spline is? I need to make new 2D and 3D sketches for the right spline?
Message 8 of 22
WHolzwarth
You can use only one sketch, but things don't get easier in this special situation.
I've made further steps, but I think @Anonymous should look at this..
I couldn't get the Loft completed with 3 sections and 4 rails. Some working around was needed.
Walter Holzwarth
Message 9 of 22
@JDMather if you have time can you help me? 😕
Thanks in advance!
Message 10 of 22
WHolzwarth
Smiley Wink Ok. Some spare time left for myself ..
Walter Holzwarth
Message 11 of 22
I'm sorry but I'm just very desperate for some help quickly to finish this model. I have some more that I need to finish. I use these models to practice me, so I can be ready for a test of inventor about a week.
Message 12 of 22
WHolzwarth
This is no easy task for beginners, and it seems to be a general problem for lofting with Inventor 2017.
That's the reason, why I notified Johnson from Autodesk QA
Walter Holzwarth
Message 13 of 22
Thank you for that!
While I am waiting for help I will try and see what I can create
Message 14 of 22
asiteur
All that lofting and those splines are pretty annoying and not really the core of what Inventor is made for.
Anyways, I worked a bit on the latest model I could find in this post.
Building a loft can be annoying, as they fail often. I suggest to first make a loft of the horizontal circles (adapt the splines for that) and then cut out the upper part. You can use 'Split' for that. Then it didn't want to shell (which you should) so I used 'delete face'.
We've used 2 rails now, according to the excecise you should put 2 extra lines in, perpendicular to the ones you have. Given the shape, you probably need that. The combination of splines + lofting is just trial and error, I suppose that is also why they do this kind of excercise.
But we're good on track I guess.
Good luck!
Alexander Siteur
Project Engineer at MARIN | NL
LinkedIn
Message 15 of 22
WHolzwarth
asiteur schrieb:
.. But we're good on track I guess.
I don't think, that this attempt will succeed. My latest file does better, and it's only a short way for completing the task.
I'll do that now, but I'm afraid, that eas03 can't understand, what's been done. Some experience is needed here.
Walter Holzwarth
Message 16 of 22
WHolzwarth
Here we go.
Walter Holzwarth
Message 17 of 22
I can se you have used extrude to the text.. Why did you not have use the emboss function? Actually I've tried but it won't work 😕
Message 18 of 22
asiteur
Unfortunately Embossing only works on single curved surfaces. This is a complex surface and then you can't use emboss.
Extruding will work best, if you want to keep a single height for the letters, you can cut extrude using an offsett of the body, but that, in this case won't be very easy.
Alexander Siteur
LinkedIn
Message 19 of 22
WHolzwarth
I've made an extrusion, because emboss doesn't work with 3D faces like that. You've seen by yourself. Smiley Wink
Walter Holzwarth
Message 20 of 22
johnsonshiue
Hi Walter,
I don't think Inventor Loft ever support same 2D Sketch in section selection. It is because the selecting different section profile within the same 2D sketch can get ambiguous. Also Loft is usually a protruding operation. Coming back to the same sketch may be rare. The same restriction does not exist in 3D Sketch section or 2D/3D rail selection. Please feel free to report it on Inventor Ideas.
Many thanks!
Software Test Engineer
