How to array or pattern of a feature in a conical pattern
I want to create a cylindrical part that propagates into a conical spiral so that it spirals down into a cone shape so that there is minimal space between the part and its neighbors.  It's hard to explain but maybe my attempt will demonstrate:
What I did here was create 3 separate cylinders on a plane and circular patterned them each individually with 3 different ul counts (6, 15 & 20ul).
Cadmanto
Rob,
So what is your question?  Looks like you already did it.  Or am I missing something.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
swalton
I'd start with a 3d Helical Curve in a part file as a seed for your pattern.  Once you have a curve, then I'd pattern a point along the curve by using the Rectangle Pattern command and selecting the curve as the direction.
Once I had the curve part working, I'd add it to my assembly, and use the point pattern as a seed for a component pattern of the cylinders.
I'm not sure if you will be able to control the cylinder orientation that way you want.
Steve Walton
Inventor 2025
Vault Professional 2025
I'm looking for a method that will close the holes more between the cylinders.  The size of the cylinders are all the same but not as yet fixed.  I'm hoping there is a function in inventor that will do it in one step instead of the 6 steps I used.
Cadmanto
I know this attached link is for holes, but maybe you can draw from it to create what you are looking for.
https://forums.autodesk.com/t5/inventor-forum/hole-in-flat-pattern-of-cone/td-p/2129620
Inventor Pro 2018
Best Regards,
Scott McFadden
Thanks this helps a lot.
