Announcements
How to align an Inventor part with origin planes
hugolopessilva
hugolopessilva
I have a part file, built in Autodesk Inventor Professional 2019. I would like to align this part with all 3 origin planes. As you can see, right now the part is not aligned. How can I do it?
I thank you in advance,
Best regards,
Hugo
leowarren34
Hi @hugolopessilva,
Inside the part file, you have the move bodies command which is hidden under the modify pane in the 3D Model tab.
A screencast of the above along with other methods can be found here: https://knowledge.autodesk.com/support/inventor/learn-explore/caas/sfdcarticles/sfdcarticles/How-can...
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
johnsonshiue
Hi! Since this is a native Inventor part, you can edit the sketch and constrain appropriately. You can edit Sketch 1 and add Horizontal or Vertical constraint between the center point and the mid-point of a side.
Many thanks!
Software Test Engineer
gregH38YX
Community Visitor
Community Visitor
There is no constraining within a part, only an assembly. Unless you mean making all the line black in a sketch by dimensioning sufficiently?
And if the part is already designed you don't want to go back and start over rebuilding the part at the first sketch.
How do you align a complete complex part, without redesigning the part, to the origin axes? Thnx
SBix26
The first feature of the model determines the location and orientation of everything else.  If the orientation is wrong, the first sketch can be re-defined to a different origin plane.  If the location or rotation is wrong, the sketch constraints and dimensions can be adjusted to correct this.
A file to look at would be much easier for me illustrate with, though.  Any chance you could post one and describe what needs to be different?  And what version of Inventor you're using?
Sam B
Inventor Pro 2025.0.1 | Windows 11 Home 23H2
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
