How to add parameter to iProperties?
BeKirra
Advisor Advisor
Message 1 of 23
BeKirra
I have an IPT file and need to show a dimension (parameter) value in "Description" in iProperties.
It doesn't work if I paste the parameter value (ie. d1) to "Description".
Your helps are much appreciated.
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
Accepted solutions (4)
Replies (22)
Message 2 of 23
johnsonshiue
Hi! Try this. Go to Parameters table -> find the parameter -> check Export box on the far right. The parameter will be exported to custom iProperty. You can reference it in any iProperty using angle brackets <>.
<d1>
Many thanks!
Software Test Engineer
Message 3 of 23
BeKirra
Thanks for your help.
I did exactly what you mentioned but nothing works.
X² + Y² = C²
Message 4 of 23
johnsonshiue
Hi! Sorry, one omission. You need to add an equal sign. Write it like "=<d15>." Most iProperties can be cross-referenced like this. It should work.
Many thanks!
Message 5 of 23
BeKirra
Sorry, it doesn't work either, even having a pair of quotation marks.
BTW I am on 2019.
Thanks.
X² + Y² = C²
Message 6 of 23
BeKirra
Finally I make it. But...
X² + Y² = C²
Message 7 of 23
rhasell
Hi
You have almost got it.
Snip from my model, I use custom values, but in your case, the prefix will be placed after the equal sign.
Reg
2026.3
Message 8 of 23
BeKirra
Thanks.
So it is not possible to add prefix but suffix?
I really want to have something like this:
Cylinder Ø100 x 50(h)
X² + Y² = C²
Message 9 of 23
rhasell
Hi
No, that's not what I said.
Everything needs to be placed after the equals sign, the properties are placed in <> brackets, you can put the text anywhere you want.
= Cylinder Ø<OD> x <HEIGHT>(h)
Reg
2026.3
Message 10 of 23
rhasell
Hi
Using the d15 as an example
=Cylinder Ø<d15> x <d15>(h)
Reg
2026.3
Message 11 of 23
BeKirra
Thanks. It seems to work...
How to change the precision of the values? Currently I have 3 decimal shown in iProperties.
X² + Y² = C²
Message 12 of 23
rhasell
Hi
You might need to start looking at creating user parameters which become more permanent and can be saved to a template.
To answer your question.
When the export check box is selected, a new Right Click option becomes available for the parameter.
therefore, right click on your parameter , E.G. d15
select the option "Custom Property Format"
make the desired changes to the parameter.
done.
Reg
2026.3
Message 13 of 23
BeKirra
Awesome!
So everything seems perfect!
Thank you very much. Cheers! 🍺 👍
X² + Y² = C²
Message 14 of 23
BeKirra
Just another thought...
How to make this works? Thanks.
If d1 = 10mm, I'd like to show a value in iProperties 5mm = d10 / 2.
Obviously the following doesn't work.
=<d1> / 2
X² + Y² = C²
Message 15 of 23
rhasell
Hi
The first thing that comes to mind, is a User Parameter.
The User parameter will have the formula of d1/2 and the the iProperty will report the User parameter and not the d1 value.
eg: d1=10mm
User parameter of "Length" =d1/2
Iproperty of Description =<Length>
Reg
2026.3
Message 16 of 23
BeKirra
Yep, I did think of this.
I prefer not to edit parameter(s) nor create a new parameter.
It'd be nice if it can be done in the places of iProperties.
Thanks.
X² + Y² = C²
Message 17 of 23
willianvanhoogstraten
Community Visitor
Community Visitor
Do I have to "Remember" <d15> from the parameters list or is it also possible to open the parameters box while placing in the iproperties and then select the parameter needed?
Message 18 of 23
cfairfowl
I'm confused .com
Message 19 of 23
dan_inv09
Put a check in the Export column for the Parameters you need to use
Right click for Custom Property Format
When an iProperty has = as the first character then the property will show what is after it and things in <> will come from other iProperties or Custom Properties - the exported parameters will be in your Custom Properties
Make new User Parameters if you have to do any sorts of calculations in the Parameters
And if you can remember that you need a certain Parameter then you can just use that, like <d15>, but it is easier if you rename your Parameters (just the ones you need for the iProperties, unless you really want to do more)
Message 20 of 23
cfairfowl
Hi Dan, I managed to get it to work thanks.
=<d1> <d2>x<d3>     fx at the end of the box.
PLATE 30 THICK 400x300 appears in the BOM description and in the Project Description in the iProperties.
However, when I add PLATE and THICK into the mix
PLATE =<d1> THICK <d2>x<d3>
it displays OK but it looses it's connection and then doesn't update if I change the values in the parameters.
The fx symbol at the end of the line also vanishes and I can't get it to come back so I cannot do anything with it.
Any Ideas?
Kindest regards.
Chris.
