How to add arrow on ordinate dimension
radoslav
radoslav
 How to add arrow on ordinate dimension.Option from style editor not visualization.
Cadmanto
First, I see that your styles editor is read only.  It needs to be read write.
Second, is the ordinate dimension you are referring to using the same dimension style you created in the editor?
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2020
Best Regards,
Scott McFadden
(Colossians 3:23-25)
radoslav
I did it without the result
johnsonshiue
Hi! I see the issue now. I think you place individual ordinate dimension. I don' think the arrows are allowed there. You need to use Ordinate Dim Set.
Many thanks!
Software Test Engineer
