How should i create a sprint car frame correctly in inventor?
This is something that has proved extremely difficult for me to figure out, I have the side of the frame drawn and extruded into tubes which was surprisingly the easy part. I need to be able to angle the one side of the frame so that when I mirror it using a plane I have centered in the assembly the front of the frame is 23 inches apart in the front and 24 inches apart in the back while also having a vertical taper or angle of 0.88 degrees. I attached drawings that explains what I'm trying to do a lot better. Should i try going about this process in 3d sketch entirely or should i try doing this in assembly? And then how would I do it in either of those, I've tried my luck in both and couldn't seem to figure it out. Here is my little drawing explanation
