Announcements
how do you make this part as a sheet metal part
Message 1 of 8
How do you make this part as a sheet metal part....could an example be posted of this part as a sheet metal part ..2mm thickness.. a learning exercise
Greg
Replies (7)
Message 2 of 8
JDMather
Do you realize that none of the faces are currently 2mm and there are several different thicknesses in the part you attached?
Do you have a specific Bend Radius that you want to achieve (otherwise I assume 2mm on the bend radius)?
Do you realize the corners will have to be welded or soldered?
Do you want any overlap corner flanges?
Have you installed all Service Packs and Updates for your version of Inventor?
Have you made an initial attempt at modeling this part in Sheet Metal environment?
Message 3 of 8
rmerlob
Problem is like JDMather said your corners are not manufacturable in Sheet Metal.
I´m attaching an example of your part that could possibly be made , granted I´m no expert at sheet metal parts since I´ve done mostly castings but you get the idea.
You should go into the sheet metal enviroment right away and use the dedicated tools to make your part, that way the flat pattern will be built with less problems.
Best regards,
RM
Message 4 of 8
JDMather
RM
What version of Inventor is the OP using?
Message 5 of 8
rmerlob
I tried re-saving his part and as it didn´t give me the ´´file is going to change versions´´ prompt I´m guessing 2016.
EDIT: yeah nevermind I tried it again it is a different version. so im guessing he won´t open it.
I´ll post the browser tree and an stp.
RM
Message 6 of 8
rmerlob
Well, as it seems you arent going to be able to open the file I´m attaching the tree and an stp file, im sure you can figure it out from that.
RM
Message 7 of 8
JDMather
Attached is one possible solution.
I might move the origin datum to the top or bottom (relative to the view cube) depending on the design intent.
Message 8 of 8
Lots for me to view and learn....thanks for the time you gave to give examples
Greg
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
