how do I turn off any type of smart snapping when trying to trace an object?
chris
Advisor Advisor
Message 1 of 10
chris
I'm trying to trace an existing profile of an object with splines, but its difficult because the stupid little HUD keeps trying to be right where I need to click my cursor and the cursor keeps trying to snap to "perceived" constraints... how do I turn all this stuff off while I draw my spline?IV issue.PNG
Replies (9)
Message 2 of 10
BDCollett
You can click and move the hud while drawing the spline, I usually just hold CTRL to stop any snapping.
Message 3 of 10
llorden4
You might want to try turning off any Inference constraining.  This can be done in your Application Options.  Just uncheck the box to disable them.
Autodesk Inventor Certified Professional
Message 4 of 10
SharkDesign
Holding ctrl whilst sketching is best because then you don't have to remember to turn it all back on again.
Message 5 of 10
chris
jameswillo, thanks, but how do you get rid of that stupid box... which seems to always appear right where you are trying to click, then if you click to fast it ends your spline when you're not finished?
Message 6 of 10
SharkDesign
Can you not drag it out the way?
There's an option too to turn off mini-toolbars, not in front of my
computer at the moment though.
Message 7 of 10
chris
yes, if its just a few moving it out of the way is not a big deal, but the selection I did last night was about 90 points I had to "trace" and it required that I move that box almost everytime as well as click for each point all while holding cntrl the entire time and panning with the space bar... had that box not popped up with every click I could have stayed zoomed out and finished in a 1/4 of the time.
That box is not user friendly for things like that
Message 8 of 10
SharkDesign
Ahh, sorry, turning off mini toolbar doesn't turn off that annoying box unfortunately.
Message 9 of 10
BDCollett
Middle mouse pans. I can't see why the box is getting in the way either, it only moves AFTER you make the selection. It has never caused me this problem when tracing so I have to wonder the way you are doing it?
Message 10 of 10
Shag_Bore
Does anybody know what snap settings that the CTRL button is suppressing while being pressed?
I have unchecked the Application Options->sketch tab->constraint settings ->Inference tab->unchecked infer constraints
but while trying to trace an imported dwg, the pointer is still trying to snap to one of the thousands snap objects on the dwg.
Thanks!
Sean Farr
Product Designer at Teksign Inc.
Inventor 2016 SP1
Dell Precision 3660
i7-12700 @ 2.40GHz-4.90GHz
32GB DDR5 4400MHz RAM
NIVDIA RTX A2000 6GB
