Inventor Forum
This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. To translate this discussion, select the language.
Inventor Forum
Highlighted
Post 1 of 4
How do I tell What Layer a Line is On.
244 Views, 3 Replies
07-03-2012 07:54 AM
When I edit a title block I would like to know which layer a particular line is on.  If I right click to activare the "Properties" dialog box.  All it tells ne is that the line is "By Layer".  How can I tell which layer an entity is on?
Thanks!
Michael Crump
Michael Crump
AutoCAD 2013
Inventor 2013
Windows Pro 7 x64
Asus Sabertooth X58
Intel Core i7 960 @ 3.2 GHz
24 GB ram
Hi mcrump28210,
Select the line(s) and then switch to the Annotate tab, and look for the Format panel. You'll see the layer drop down box listing the current layer. You can use the drop down to change the layer if needed.
I hope this helps.
Curtis
Re: How do I tell What Layer a Line is On.
07-03-2012 07:57 AM in reply to: mcrump28210
Hi mcrump28210,
I hope this helps.
Curtis
 Inventor Improvement Ideas that needs support:
Post 3 of 4
07-03-2012 08:02 AM in reply to: Curtis_Waguespack
Thanks Curtis!  BTW, I have all of your books and they have been of tremendous help to me.  Thanks Again!!
Michael Crump
AutoCAD 2013
Inventor 2013
Windows Pro 7 x64
Asus Sabertooth X58
24 GB ram
Post 4 of 4
06-10-2013 03:39 PM in reply to: mcrump28210
Curtis,
Is there a way to create a titleblock in Autocad and use it as the basis for an inventor titleblock without creating extra layers.  BTW, as a SC native, born and bred, GO GAMECOCKS!
Mike
Michael Crump
AutoCAD 2013
Inventor 2013
Windows Pro 7 x64
Asus Sabertooth X58
24 GB ram
