Message 1 of 12
How do I split parts with an imported 3D surface?
I'm designing some oddly shaped strips of plywood that are too big to fit in my CNC, so I am cutting them in sections and gluing them together with a fingered lap joint. My plan was to model the whole piece and then use the split command to divide them into separate solid bodies. I have designed the fingered lap joint, and I used the thicken command with an offset of zero to make a surface of it, then exported it, then made a derived part that contained just that surface. Now I'm stuck.
How do I output that surface to a file that I can import into a part file?
