Hello Folks,
Disclaimer: Longtime SolidWorks user.
I am desperately trying to create a lofted feature. This feature is rather simple in comparison to some things I've done quite easily in the past using SolidWorks.
There's a closed profile at the top and another at the bottom. When I invoke the Loft command, I select the top and bottom profiles and Inventor previews a solid body that represents a simple, striaght projection. The problem is when I select a Rail (or any combination of Rails), the solid preview disappears and I get error messages of varying vague content.
I have yet to select the two profiles and a Rail and have Inventor produce a solid Loft. I have tried several variations of geometry and methods of invoking the Loft, including simpifying the process.
Here comes the part where I appear to prompt abuse from others: This is something that is so painfully simple in SolidWorks that, using SolidWorks, its easy to create Lofted features that are not what I want the end result to be. But, because SolidWorks actually returns lofted geometry, right or wrong - by selecting multiple profiles then one or more paths - it's easy achieve what I want by process of elimination. By playing.
This is something that is important for me to learn.
The part I've attached is an attempt at creating half the part, then mirroring the Loft to create the desired part.
Mel
