How do I pattern along a path in an assembly?
lelouchparanoid
lelouchparanoid
johnsonshiue
Hi! Please take a look at @JDMather's posting. There are a few other threads too. Basically, you need to create a feature pattern (circular, rectangular, or sketch-driven pattern of a workpoint in a part). Then reference the feature pattern in assembly component pattern.
https://forums.autodesk.com/t5/inventor-forum/is-it-possible-to-pattern-a-part-along-a-path/td-p/544...
Many thanks!
Software Test Engineer
JonathanKruger
I am not sure if this will help but maybe this old screencast I made can be useful? The only difference is I would incorporate the surface model with one of your conveyor files where in my example I had a seperate file for just the path. This method allows the pattern in the assembly to update based on the pattern in the part
https://autode.sk/2T5xtcM
If this solves your issue please mark this posting with the "ACCEPT SOLUTION".
If you like something that was said or if it was helpful, Likes are appreciated. Thanks!
