How do I move hole?
How do I move hole?
st32-22
Message 1 of 8
How do I move hole?
st32-22
It should be there I know we did it in class, but I forgot how I tried using move feature but it's just to move it randomly without using dimensions
Replies (7)
Message 2 of 8
JDMather
@st32-22
Attach your *.ipt file here.
Also include image of what you are attempting to model.
Message 3 of 8
st32-22
Message 4 of 8
JDMather
Sketch1 is missing dimensions on the smaller rectangles and has a repeated 80mm dimension.
Sketch2 is missing two dimensions for location of the point.
Sketch3 is missing dimension(s).
Sketch5 is not needed - edit Sketch2 and add the dimensions there.
Hole in "post" should only go through one of them, not both.
Message 5 of 8
st32-22
What dimensions are you talking about? I delete them because I don't need it, I add it after in the iso idwg or whatever thing
Message 6 of 8
JDMather
@st32-22
Do not, I repeat, DO NOT delete dimensions.
Your dimensions control the geometry - control the world.
If you don't learn anything else out of this class, you should learn that you do not delete dimensions.
It is stuff like this that results in children cheering the destruction of rocket and launch pad that they designed - ignoring 50+ years of experience that came before them.
Message 7 of 8
st32-22
Okay, sorry. How do I move hole for 15mm right though?
Message 8 of 8
JDMather
Edit Sketch2 in your file.  Add missing dimensions.
