Ok. Thanks for that. Before you go on, I did receive a solution to the problem. So it's up to you if you still want to invest time in it.
Here's a step by step explanation.
Put a point in a sketch on the front of a sheetmetal.
Name it's constraints. (I think it was offset.)
Put a slot on it. (with a centrepoint slot command!!!)
Add a rectangual patern to it.
Defined the number of slots and spacing with a formula to define the SPACING and NUMBER of slots, depending on the LENGTH of the strip.
Named these parameters.
Imported this part into the assembly.
Constrained it in all directions.
Shared the slothole sketch.
Put the tzstplaat in edit mode
Projected the slotplate's sketch on it. (This is the point where I can NOT select the centerpoint of the slot so I have to call for the initial parameters of the centerpoint from the slot and define it's constraints to the sides of the projected slot plate. )
Then I add the hole's in the tzstplate.
I aded a form to the slotplate ipt in Ilogic to define the length of the slotplate.
If I then LENGTHEN the slotplat, it atomatically adjusts the length and the number of slots in theslot plate IPT. But NOT in the Tzstplate ipt. If I shorten it, It all folows.
The solution I found is redefining the hole's in the tzstplate with the same parameters I had for the slot definition in the slotplate ipt. But projecting them was clearly not a workflow that did the trick.
I hope this clarifies the corrupted workflow I used. I just could not get my head around the fact that projecting geometry is not functioning as good as I was expecting. Apparently you really need to completely redfine the hole positon and parameters on the new part if you want them to correspond with the position of the slots. Counterintuitive if you ask me. And it defies the whole concept of adaptivity if you ask me. But hey, I'm just an aspiring designer. Not a vetted one yet...
Cheers!
