How do I make "ghost" or imaginary Lines in Sketch for reference only?
IIRC in Solid Works these are called "reference geometry" and when you click on "Lines" the have regular solid lines, maybe arcs and splines, but also a DOTTED line.  You use the dotted line for stuff like line to Mirror around, but unlike in Inventor you don't need to trim the mirror line, because in SWs its not considered a "real" line in the sketch.
Pardon such a basic question.  I KNOW I've used it before, just getting back into Inventor and CAD after couple years break.
leowarren34
Hi @Anonymous,
In Inventor we have construction lines that are dotted, you can use them by toggling the option in formatting (shown below) by either having construction lines turned on at the time of sketching a line or by selecting a line and then toggling the option. As you said they can be used to define geometry but are not used in the command itself.
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
