how do I label parts in an assembly
Message 1 of 17
I have created an assembly, and I want to add text with arrows to label the parts (i.e. bearing, seal, electrode, etc).  This is a section view, and I want to use it for a presentation (I'm not looking for how to add dimensions).  Is there a way to do this?
Replies (16)
Message 2 of 17
mpatchus
You could use LEADER TEXT and pull one of the iProperties from the part, (shown below using the Inventor tutorial files)
Or you could manually type the part.
Obviously not a section view, but the same principles apply.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
Message 3 of 17
mcgyvr
Leaders as stated by Mike..
You might want to look into creating a new presentation file where you can do exploded views,etc.. too..
Message 4 of 17
Cadmanto
unless you want iproperties as have been suggested.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 5 of 17
Curtis_Waguespack
Hi bheskitt,
Leaders as everyone else mentioned, or Balloons:
http://help.autodesk.com/view/INVNTOR/2017/ENU/?guid=GUID-491D178A-5C7A-485F-902A-46B1A02D1D09
Note that you can change your Balloon style to look like a leader, and you can change it to pull in any iProperty you want, therefore ballooning will be more automatic than adding leaders.
I hope this helps.
Curtis
Message 6 of 17
Thank you all for quick responses.  The screenshot you showed does not look like mine.  I am using inventor, and have the assembly open in that.  There is no annotate tab.  So are you in another program?
thanks,
Brian
Message 7 of 17
swalton
All the answers so far have used the drawing environment of Inventor.
See http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-374B6CC8-B839-4450-8172-2B1174DE9E7D for a quick video.
If you are using Inventor 2018, you can use the new 3d annotation tools in the part or assembly environment.  See: http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-B8779786-A71C-4A5C-B9A9-7EB1A9918946  In the past, I have used a position rep as an exploded view of an assembly.
I don't think that the presentation environment has any annotation features.  The normal workflow is to create the iam file and add it to a new ipn file to create the exploded view.  See http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-2A480981-2E53-4408-BFA9-290C14F03C95
Steve Walton
Inventor 2025
Vault Professional 2025
Message 8 of 17
Curtis_Waguespack
Hi bheskitt,
You will need to open a drawing, place a view of your assembly, and then add the leaders or balloons.
I hope this helps.
Curtis
Message 9 of 17
Ah... I understand now.  Thanks for that.  So the 3d annotation tool is not available for assemblies? 😞
Swalton, thanks for your post.  Your first link was very helpful.  BTW, your second link about the 3d annotation tool is broken.
I wonder/hope that some day the 3d annotation tool will also be in the assembly environment.
Brian
Message 10 of 17
Thanks to all for your help.  As you can probably tell, I am very new to inventor.  I haven't delved into drawings yet, so don't know if it will give good results.  FYI - for the immediate need, I decided to export as an image and label it in Powerpoint.  A bit of a lazy cop-out, but I know how to get the assembly looking the way I want in the assembly environment, and I didn't want to invest in another learning curve right now to get it looking the way I want in the drawing environment.
Brian
Message 11 of 17
mcgyvr
Nope.. 3d annotation is half finished... When something is "new" from Autodesk you can just about guarantee its half finished..
3d annotation is brand new for 2018..
If Autodesk made cars you would buy one only to find out it only turns left... Right hand turns will be available as an update later in the year or on next years models... Smiley Very Happy
Message 12 of 17
mcgyvr
Brian
Its "REALLY" easy though... You should try it.. I'd bet you could have finished it before you did in powerpoint..
Create drawing.. place base view... add leaders.. Should take all of 3 minutes flat if that..
Message 13 of 17
I have tried a little, and so far have made a relatively ugly isometric view that I haven't figured out how to section.  I already have a beautiful sectioned assembly, which is what I loaded into the drawing, but the section also does not transfer in.  I suppose I will eventually learn this, but the learning curve is too steep in the short term.
Message 14 of 17
Light_Guy
So, even though it states that the annotations are in the assembly environment in the Whats New section:
Assemblies
3D Annotation for Assemblies
A new Annotate tab is added to the ribbon in the assembly environment. The new tab contains commands that let you add dimensions, notes, and other information to your assembly.
It really means part environment. KILLING ME....
Paul Hamor
Senior Designer/CAD Manager/Data Manager
"Always Good Ships!"
Message 15 of 17
swalton
Maybe.
It looks like 2018 shipped with 3D annotations in the part environment.
The "What's New" for the 2018.1 release says that 3D annotations were added to the assembly environment.
I have not installed either, so I don't know for sure.
What version are you using?
Steve Walton
Inventor 2025
Message 16 of 17
JDMather
I just used in the Assembly environment?
What version of Inventor 2018 are you using?
Message 17 of 17
I am using 2018 version, build 112, Date 2/16/2017.  Light_Guy, I am not seeing the tab you are referring to in the assembly environment.  For now, I am just exporting and annotation in another application.  It doesn't come up very often.  Thanks for your replies.
Brian
