How do I get an overview?
Is it possible to assign a label that appears when I move the mouse over the drawn elements in a Sketch?
I have a great responsibility to keep an overview of the individual parts,
Open to all possibilities
Inventor 2016
See picture
Solved by Lewis.Young. Go to Solution.
The method that comes to mind would be to, right click on the circle you want, select "Create Note" and then call that note whatever you like (Left wire, right wire etc.). An engineers notebook is now created and when you open that, each separate note will reference a piece of geometry.
Lewis Young
Windows 7 x64 - 32GB Ram
Intel Xeon E5-1620 v2 @ 3.70GHz
nVidia Quadro M2000 - 4GB
Inventor Professional 2017.3
Vault Basic 2017
3ds Max 2018
Hi @steenH797P,
From your screen grab it looks like you might be doing something a little outside of the normal workflows we typically see in Inventor.... can you explain a bit more about your overall goals and workflow?
If so someone might be able to offer some more specific suggestions, but in the mean time my best guess would be to look into creating Sketch Blocks in your sketch (assuming the sketch is in a part file, rather than a drawing sheet sketch).
I hope this helps.
Curtis
Almost like you want to add leaders in your model sketches?
Or maybe like pdfs, adding flyout popup notes?
If that is the case, other then creating a drawing identifying what you need, then maybe iLogic to do this?
Other then that, there is nothing presently. Maybe input an idea in the Inventor IdeaStation
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Isn't exactly what you want but just a suggestion: https://autode.sk/2yokdrd
Lewis Young
Vault Basic 2017
3ds Max 2018
Not a popup, but you could assign geometry text to your elements...?
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
I don't know anything about "Blocks" - please explain what exacly blocks is ?
And why I shall use it.
Lewis Young
Vault Basic 2017
3ds Max 2018
@steenH797P you can name each parameter and then have the title show based on the Document Settings as Named or Expression.
That would probably lead to the best Inventor workflow anyways.
Please select the Accept as Solution button if a post solves your issue or answers your question.
* Ideas * Help * AKN * Updates * Pack & Go * Reset Utility * Repair Install * Customization * iLogic Examples * Autodesk University *
My question is (since I read your posting two-ways).... Are we talking about a sketch in an Inventor drawing or at the part (or assembly) level? Its hard to tell by your clipped image.
Mark Lancaster
& Autodesk Services MarketPlace Provider
