I would like to only export the second level of my structured BOM tab. I am aware that it is possible to export the first level only or all levels of the structured BOM tab, but is there any way to export only the second level, which is the level at which each of my main assemblies are only expanded once, i.e only export item no's 2, 2.1, 2.2, 2.3, etc... instead of 2, 2.1, 2.1.1, 2.1.2, 2.1.3, 2.2, 2.3, etc...
I am asking since some of the sub-sub-assemblies in my main assembly is made up of parts with irrelevant part names, such as 5531-2331.ipt, 5531-2332.ipt, etc..., and I don't want those to show up in my exported excel document.
A few ways of doing it manually would be to export the all-level structured BOM tab to excel, and then manually deleting the rows with the irrelevant part names to reach the desired structure, or, export the first level of each individual sub-assembly and manually combine them into the larger assembly in excel.
Is there any way it can be done automatically?
Solved by b.mccarthy. Go to Solution.
What is your workflow? Some of the ilogic gurus may be able to develop a script to simplify this.
