How do I create an iassembly where each assembly has its own mass.
jheinerBAW9W
Observer Observer
jheinerBAW9W
Observer
Observer
I have an iassembly which has multiple different motors.  Instead of putting each motor in and having multiple constraints and include/exclude columns in the table I figured I would make a "sub" iassembly with just the motors in that.  As far as reducing all the different mating and on/off columns in the table, it works great.
However, I need each motor to have its own weight and iassemblies seem to only put one weight for all. I overrode the iproperty mass in the motor part files and also tried making a custom mass property in the table and then running
mass=iProperties.Value("Custom","Mass")
 in ilogic but it ends up applying the weight of which ever motor is up to all of just one.
I've never used ilogic before this, so I have pretty much no idea what to do on that end.
Using Inventor Professional 2024
johnsonshiue
Hi! I vaguely recall there is an iLogic rule somewhere to automate that. Basically, you need to place the iAssembly members in an assembly -> Update mass -> save all files.
Many thanks!
Software Test Engineer
