How do i create a revision table template
i have made and exported a revision table into .xls format and i am wanting to somehow make either the .xls file or make the revision table in the IDW into a style that appears in the format tab when you make a revision table.
Please help
Huw
cbenner
Hi, and welcome...
What do you mean by: ...appears in the format tab... ?
To make a revision style available to all of your new drawings, create the style you want in the Styles Editor inside your template drawing.  To make the same style available to older drawings, right click the revision table style in the Styles Editor window, and select "Export".  It will be saved as a .styxml file.  Make sure you put it in a central location.  Now, to add it to an older drawing, open Styles Editor in the drawing and use the Import button at the bottom.  Select the file you have saved.  This only adds the new style to the editor though... to make it active, you need to add it in Object Defaults.... also in the Styles Editor.
Hope this helps, good luck!
by format tab i mean when you are choosing a style in the format tab it doesn't appear. i want a .xls or import the table so it appears in the styles drop sown menu in the format tab.
I shall try your solution first before asking again
it has kind of worked. How do i make it so that the table i have created doesnt need to be imoprted seperately every time i open a new drawing?
cbenner
You need to create this style in your drawing template file.  Then it will be in all new drawings. The Import is for old drawings created before you added this to your template.
