I got this file that is completely made out of surfaces and for some reason it's in an assembly. I don't know. I tried deriving it but it still has ties to the original file.
Anyways I need to get this into a sheet metal and then fold it out but I don't know how. I wanted to delete all faces and then thicken/offset it and then conver to sheet metal but for some reason I can't choose any sides. Anyone has any clues what's going on with these files?
Thanks!!
Solved by WHolzwarth. Go to Solution.
There are different ways of doing, depending on your STEP import options.
Try this:
Ribbon Launch -> Open -> Select 101418446-Test.stp as sample -> Options
Now there are two ways:
1. No hook at "Import Assembly as Single Part"
- Click Ok -> Open. You get an IAM
- Open Selection.ipt in this IAM
- Convert to Sheet Metal
- Ribbon Setup -> Sheet Metal Defaults -> Set Thickness to 1.5mm
- Create Flat Pattern. It does only party. Two flanges are remaining.
- Switch back to folded Model
- 3D Model -> Delete Face (Option Heal) -> Select the outer edge fillets of the remaining flanges in the flat pattern -> Ok
- Fillet both new edges again, now with 3.5mm instead of former 4mm
- Try flat pattern again. Now it's ok.
2. Place hook at "Import Assembly as Single Part"
- Select "Single Composite Feature" in next row
- Click Ok -> Open. You get a Composite ->
- Select Composite1 in Browser -> Ribbon Surface -> Stitch ->Apply -> Done
- Convert To Sheet Metal
- Same steps now as above
Walter
Walter Holzwarth
