How do I add a field note in inventor. Field note is a note with a box around it or a triangle.
Solved by mcgyvr. Go to Solution.
Field notes/Flag notes,etc... is something you will need to use sketched symbols for in Inventor..
There is no field note/flag note tool
https://forums.autodesk.com/t5/inventor-forum/adding-flag-notes-to-a-drawing/td-p/6525463
hey there, I actually just noticed something. Just under the insert symbol is a letter A if you pick it you can make field notes with a box around them!! Insta field note =)... thinks its something new in 2019
RB
RB
If thats what a field note is to you.. Then there you go..
That is not what I though you were referring to..
That just puts a border around all the text.. If thats all you need then great..
I assumed you wanted individual line border/flagging capabilities not the entire text element..
Border text was an enhancement in 2018
