How Did Smiley Face Show Up In Pipe Run List?
Any Ideas? cause i can't work it out again...
kelly.young has edited your subject line for clarity: How did i manage to do this?
☺☻ these are made using alt codes for example alt+1 on numeric keyboard makes first face. Inventor from time to time throws some extra letters or signs into text that you are typing li♣ke that.
The solution is just to change name and delete the sign.
kelly.young
Autodesk Support
Autodesk Support
Hello @Anonymous not sure how you got that in there, would be very obscure to hit the right Unicode command.
Maybe you had it copied and accidentally pasted into there?
As far as I know smiley faces are not built into pipe runs, sometimes it does make frowny faces in real life though @cbenner Smiley Wink
Please select the Accept as Solution button if a post solves your issue or answers your question.
