Inventor Forum
how cut through solid body paraler to x plane on different planes/faces
8 REPLIES 8
Message 1 of 9
lekoky
456 Views, 8 Replies
Hi I don't know much at all about inventor, slowly learning.
I am stuck. I have a solid body object which I need to cut at the top and bottom parallel to the x plane.
How do I do that?
Can you please show me. I have attached the file.
Thank you
8 REPLIES 8
Message 2 of 9
lekoky
in reply to: lekoky
Additional drawing, thank you
Message 3 of 9
lekoky
in reply to: lekoky
Message 4 of 9
JDMather
in reply to: lekoky
The Attached is a wild guess as I really have no idea what you are after.
Message 5 of 9
Cadmanto
in reply to: lekoky
Are you looking for something like this?
See attached model.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2020
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 6 of 9
lekoky
in reply to: Cadmanto
@Cadmanto Yeah, that is. How did you do that? I have the file open but as mentioned I have not much knowledge of Inventor.
Did you draw two rectangulars and somehow made them cut through.
Can you pleas show or explain to me.
Thank you.
Message 7 of 9
lekoky
in reply to: JDMather
Hi @JDMather Yes, the first file is what I am trying to achieve. Do I just sketch the rectangular shape on one particular plane and then use slice or cut tool? Or what is that extrusion. I will have a go but if you have time please let me know. Thank you
Message 8 of 9
lekoky
in reply to: lekoky
ok I have got it now. only if I would ask here 2 hours before. thank you very much @JDMather @Cadmanto
Message 9 of 9
Cadmanto
in reply to: lekoky
Did you figure it out?  Is this thread resolved?
My suggestion to you would be to go through the tutorials supplied with Inventor and also look at ones on Youtube.
Inventor Pro 2020
Best Regards,
Scott McFadden
