Hello, I have here a snapshot and I need to generate a curve like what is shown..Is there a way?
Thank you
Thank you
See attached. I imported your image and then trace it.
Does that work?
Brian
You didn't include a crucial piece of information: what version of Inventor are you using?
The attached part file (Inventor 2020) contains a 3D sketch of a spiral matching your image, I think. Here's what it looks like:
Edit: I see on re-examining the image that I didn't get the Pitch parameter quite correct-- should be 2.25mm instead of 2.00. But easily corrected.
Edit #2: Still not correct. The diameter should be 2.00mm, not 1.00mm.
Sam B
Inventor Pro 2020.1 | Windows 7 SP1
LinkedIn
Thanks sir, I have Inventor 2019 but I knew the method you are talking about..Thank you so much !
Thank you, this is good too..I have used thicken to create the 3D model..Here is the snapshot.
