How can I make money with Inventor?
I'm looking to make some extra money using inventor. Can anyone give my some ideas on how I can use inventor to make money??
Replies (39)
JDMather
How much training/experience do you have?
Can you post the url link to your ePortfolio?
I work as a mechanical designer, I've been using inventor for about 8 years. I will post a link tomorrow after work
Sent from my iPhone
Like to know more on how to do this also
Do you have any interest in doing private work?
S_May
Hi @Anonymous
What products do you master, do you have customers for. What did you design for products in the past?
Do you know with simulation and FEM, or a sheet metal production, only inventor is not enough!
att82glass
I want to join too
att82glass
my email: att82glass@gmail.com. I'm very happy to do 3D modeling
att82glass
I want to join too, my email: att82glass@gmail.com
***Edit*** Sorry, just realized this was originally from 2016...ugh.
Where are you located? Here in the States you'll need to at least form an LLC to contract yourself out to local businesses. I assume that's what you are wanting to do.
How good are you at cold calling? You'll need to go door to door at times and drum up the business.
How much do you plan to charge? How does it compare to your competition in the area? Do you have a website that showcases your talent?
I have my consulting firm on hold as I'm working full time, but I'm starting to look to drum up work as I have 3 people who could use the income. They all work as contractors on a 1099 basis.
Again, if you're not in the States, things will differ, but if you are, I might be able to find you something based on your abilities.
JDMather
Can you do detail drawings?
ePortfolio?
att82glass
I can model the part, assembly, simulation... and ofcouse we can do the detail drawing. Dear...!!!
JDMather
Attach some Inventor files here.
att82glass
what kind of file do you want to check Sir, I have alot of inventor file, ipt file, asm file, idw file  you can show me your email, i will send you Sir
att82glass
detail drawing
JDMather
Unconstrained sketches.
Threaded holes wrong size.
Bits of extraneous geometry.
Fasteners should be multi-body.
JDMather
The "detail drawing" is an image file of poor quality and cannot be clearly read.
I would use a high quality pdf in my portfolio and be prepared to supply in idw or dwg format along with the ipt file.
MoshiurRashid
To make money, you should understand the need of a cad software like inventor in the industry. Assuming you know that. Answer of your question is,
1. You can be a freelancer in an freelancing website
2. You can be a full-time mechanical designer in a particular company
3. You can be a part-time mechanical designer in a particular company
Now, to me, Inventor itself is an industry. If you know this software well, you can do almost all kinds of designs related to metal, plastics, wood etc materials. Now, how can you be able? It depends on your design sense. How a part is created in real life, what are the problems do manufacturers face while producing something and what are their machine specifications. After knowing all the aspects, you can start design. But you must know the software manner well also so that you don't get stop in the process.
Wish you good luck.
Moshiur Rashid
Autodesk Certified Instructor
ACP | CSWE
https://www.autodesk.com/expert-elite/overview
LINKEDIN | FACEBOOK
att82glass
Thank you, I spend a lot of time on 3D modeling, I haven't spent much time on detailed drawings, but if you give me a chance I will make you the best because I have a good Inventor team. You can open the Workspaces folder to check the new ipt and idw files, hope to do something with you
JDMather
M8 tap drill size incorrect.
There will not be any material for threads.
