What is your goal?
Jürgen Palme
I have an external application at Inventor that I must work i network location M:/. In this external application have I some trouble that I don’t have when I am working in C:/. I have concluded that if I can delete the .lck file, I solve the problem 🙂
Hi! The existence of .lck file is to prevent another application from editing the file, when Inventor is editing it. I am not sure deleting the file will benefit anything. Are you trying to edit the file when Inventor is editing it? You can open the file but you cannot edit it. It will lead to file corruption.
Could you elaborate what you are trying to do?
Many thanks!
Hello, after changing workstations and update to version 2020, the security lock(.lck) for files that are already open no longer works. I see the lock file created. Its interior is empty.
What advice do you give us? What checks should we do? Thanks
Hi Roberto,
.lck file is indeed empty. It is there to let Inventor know that the file is already opened by Inventor. It does not block another Inventor session to open the same file. But, whoever has the .lck can save the file.
Many thanks!
Hi! Opening files in multiple sessions is fine. It is about saving. .lck file prevents another session to save the same file.
Many thanks!
