Inventor Forum
How can i capture dimensional information see doc
2 REPLIES 2
231 Views, 2 Replies
Anyone know how to copy clip dimensions from a drawing in inventor?
Thanks!!
2 REPLIES 2
Cadmanto
What exactly are you trying to accomplish?  These same values are also in the parameters.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
johnsonshiue
Hi! If I understood you request correctly, you would like to copy the model dimension value, right? This is a bit tricky. In the dialog, the values are all grey because they come from the model. You can open the part and find the parameter value. Or, you can click on Override Display value checkbox and copy the displayed value. Make sure you uncheck it afterwards.
Many thanks!
Software Test Engineer
