How Can I build a model to calculate stiffness of a tapered coil ?
Hello ;
I have been trying to construct a model that I can use to calculate the stiffness of a tapered coil. I tried constraining one end and applying remote force command but the displacement occured in more than one axes. What I need is apllying different forces and recording the corresponding linear displacement values, then I will use this displacement to calculate the stiffness. I created my coil correcrtly but could not make it compress and elongate on axis that runs through the center of the coil. Could you help me with this, what should I try ?
[image added by CM from duplicate post]
