Announcements
How can I add a balloon in a custom place in 2D drawing environment
hugolopessilva
hugolopessilva
I designed a part in inventor, and I want to do the set drawing of it. However, it is much easier for me to do a single part than to do an assembly. What I want to ask is: How can I add a part ballon with the identification number to a set drawing pointing to custom places? and how can I edit the generated table with the parts list, editing the parts names? Because what I can do is only pointing ballons to parts belonging to an assembly, not in custom places in a single part.
thanks in advance,
regards,
Hugo
mdavis22569
You can make a custom parts list ...and "insert" your own part into it
problem I see,  is you'll need dumb model to base the parts list on. Turn off everything in that parts list and then insert custom part, put your numbers in it and description etc ...
undefined
Mike Davis
hugolopessilva
Many thanks for the reply.
Is it possible to add the ballons in this case? or is it only possible to edit the parts list?
mdavis22569
I'm testing something ..
but no because it's in the part level, and you want to match the assembly level numbers.
You'd have to edit the parts list ..but there should be a quicker way.
Mike Davis
dag_h
If you want to balloon your added "custom parts" from your parts list, you can do it this way:
Balloon an item that actually exists on your drawing. Right click this balloon, choose "attach balloon from list". When you now have your custom part balloon, right click again, on the original balloon and choose "Remove balloon".
This balloon should keep track of your custom part's pos number through "renumber"ing.
As for how to match the part list numbers to other lists, I can't help with that.
cwhetten
This all sounds like too much work to simulate the behavior of an assembly.  You should just learn how to do it properly as an assembly.  Once you practice a bit, it is not hard at all to create assemblies.
If you still prefer to model it all in a part, you should learn how to use 'multi-body' or 'multi-solid' modeling techniques.  This way, you model it all in a single IPT file, but each part is created as a separate solid body.  When the part is done, it is a simple matter to convert it all to an assembly with individual parts that are all linked to the original multi-solid part.  This way, you can model it all in one part, but still utilize the full power of Inventor's BOM tools.
It's definitely worth the effort to learn both of these skills.  You'll be much faster and less frustrated in the end.
Cameron Whetten
Inventor 2014
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
