Horiz/Vert Sketch Constraint Graphical-Preview Bug
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
We just migrated from 2022 to 2024. Specifically using Inventor 2024.2 // 29.20.27200.0000
I and several other users have experienced problems with the graphical-preview/reference line for the Horizontal and Vertical sketch constraint while editing a part-sketch in an assembly context. To be clear, I mean editing a sketch within a part component, by double clicking it in an assembly. The top level "active document" is an assembly, the "active edit document" is a part component of that assembly.
The constraint preview graphic line is displayed according to the ASSEMBLY horizontal/vertical rotation, and NOT the part.
I've been able to reproduce this by:
1 - Create an assembly using Standard.iam as the template.
2 - Start the Create-Component command to create a new part using Standard.ipt as the template.
3 - Fully constrain that part to the origin places of the assembly, such that it was rotated along the assembly XY plane some number significant enough to see visual misalignment (30 degrees in the attached example)
4 - Right click on the component in the assembly model browser and click "Open"
5 - Create a sketch on the XY plane of said part and draw a line at some skewed arbitrary angle.
6 - Save and Close that part
7 - With the Assembly now the active document, double-click the Part component, to "edit component in place"
8 - Edit the sketch created in step 5
9 - Click the horizontal constraint button and observe the graphical preview line is incorrectly aligned
We also experience this issue with old parts from 2020, 2018, etc that have not yet been migrated, when we edit their sketches in an assembly context / 'edit component in place' context.
I've attached the assembly and part that I created (I also made a 1x2x3" extrusion in the part to create the sketch on a face, but the extrusion didn't seem pertinent to replicating the problem) as well as a crudely marked up screenshot showing the graphic misalignment with respect to the part orientation.
If I go through with clicking the objects I wish to horizontally constrain... it -does- respect the part orientation and constrains them horizontally with regard to part vectors, which is different than the assembly vectors. But having to know the part orientation kind of defeats the purpose of the preview/reference graphic line, doesn't it? 🙂
edit-to-add specific version info
